Tried the CNC module on my Snapmaker1 for the first time today.
- Damn that thing is loud!
- Learning curve? More like learning cliff with overhangs. For some reason my tool wants to generate the pattern mid-air. And I can figure out the reason why.
I’ve designed a simple jig in Fusion 360 to jold those 80 mm x 80 mm mdf and delrin sheets I got with the Snapmaker (link: https://a360.co/2N2W6Z3)
The set-up was described on the Snapmaker homepage along with the correct settings, tool library etc.
I set work origin to 0.1 mm above the stock. Then when I run the file, it lifts the toolhead up, but lowers it to about 3 mm above the stock and follows all the toolpath from there.
What do I do wrong?
