Black filament in spool #1 ran out and the U1 switched to spool #3, like it should, but I got a layer offset which ruined the print. The offset is in the Y direction only.
This is the 2nd time this happened. Another time the machine just stopped without switching to the other toolhead. Only once have I had a successful filament switch. Really disappointed! Is anyone else seeing this? Any ideas what’s causing this? Thanks!!
If this happened to me I’d recalibrate the heads & see if that fixed the issue. Might also be a belt tension thing.
Personally I have not had that issue when switching filaments.
Thanks for the reply. What do you mean by recalibrate the heads?l I don’t know what that is! I’ve retensioned the belt a few times now, for other issues. Interestingly, my U1 prints multi-color very well!! The prints come out really nice. It seems to be an issue when filament runs out on one head, and it switches to another.
The calibrate heads is the process where you are asked to remove the plate and let each head dance in the divot hole in the magnetic base. It is in the machine menu. I do it after an update, especially a paxx upgrade, and if I move the machine to clean and put it back on the shelf.
Yeah, it did that when I first fired it up. I’m doing another one right now. Hopefully it will fix the problem, but I’m afraid to try!! I’ll have to set up a test with a small object so I don’t waste too much filament! Thanks for your suggestion!
Scale the item in the XY to be smaller size and chop it shorter too (don’t scale shorter to avoid layer height changes) and then try a filament swap by cutting the filament after it gets a few layers tall and see what happens when it swaps.
I made a cube about 50mm on a side, and cut the filament when it was about 1/2 done! The swap worked perfectly!! The calibration did the trick!! Now I wonder why it got out of calibration in the first place!!! But, thanks for taking the time to answer my question and provide the solution!! Really appreciated!!
I can understand why calibration is important for one nozzle to take over from another without printing a defect, but I don’t understand why calibration is important for one nozzle to take over from another at all!
Glad that worked, at least on that scale. And not sure how calibration can get “knocked out” either. I never even knew about the weird calibration thing until setting up the U1 for the first time and it asked me to take of the PEI plate and I saw that divot. Crazy, but obviously necessary.
