Changing Defaults.
EDIT TAB
I add a file via the add button.
Resize to width I want (95mm x 185)
Select Greyscale
Select Process
PROCESS TAB
Defaults are Movement Dot (High Quality)
Density 7 dot/mm
Jog Speed 1500 mm/min
Work Speed 2500 mm/min
Dwell Time 5 ms/dot
The problem arises when I change the movement mode to Line and then back to Dot (High Quality)
It does not revert back to the default settings of above, but now you only get
Work Speed: 1500 mm/min
Dwell Time 42 ms/dot
and can’t see the Job Speed adjuster.
When changing settings it shouldn’t change the defaults.
