No matter what I do once I go to set the origin on device the laser turns up to maybe 20% and burns the material ever so slightly while I am moving it around. I have tried the the switch in Luban Workspace that says laser power minimum but that seems to do absolutely nothing. I am at wits end. What am I doing wrong?
I think I figured it out. I set the machine settings to the 10W laser but they will not save… Everytime I go back to it it says 1600mw… So looks like I have a different problem…
I got the laser type to be correct now, but it still turns on the laser and burns the material finding origin still. This is beyond frustrating.
This sounds really weird - I’d suggest you contact Snapmaker support.
Is your firmware and luban up to date?
Luban 4.9.1 and Firmware says latest install. I see there is a 4.10.1 Luban. Will update to that but not sure how that will help as the issue is when I am disconnected from Luban.
Upgraded to 4.10.1 and the issue still exists. But something new broke in that now when I open a DXF file it comes in at some arbitrary small size. I have both versions running and 4.9.1 works just fine with DXF files and 4.10.1 does not. So maybe a new bug.
Also I forgot to send a picture of the firmware.
<img width=“205” height=“364” style=“width:2.1354in;height:3.7916in” id=“Picture_x0020_3” src=“//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/business7/uploads/snapmaker/original/3X/0/0/00baab6b53c95777e47ea6dab899f523ba657a58.jpeg” alt="A screen shot of a phone
Description automatically generated">
There was a firmware change (1.18 I guess, not sure right now… ) which needed a newly generated file by latest luban (4.9.x).
