I have tried to do cutting directly from the printer and from Luban and get the same result. As soon as it starts to do the cut it goes to the far right corner, barely on the table. I have done the calibration a dozen times and aligned it. The background image looks great (aligned). Any suggestions?
Is Luban set for your model of SM2?
Yes, So, I’m doing a print directly from the printer but, had to set the Work Origin way off the material and use the run the boarder to make sure it is correct.
I was able to print by setting the Work Origin and then doing Run boundary. This was all from the printer screen.
