Hi All
once I load the the SVG file spaced it correctly
I hit the process button
Hit generate the G code (Generated G-code successfully)
Load load G code to workspace
it goes to this page and does not load to the workspace
what am i doing wrong just cant get it to my machine
xchrisd
February 20, 2021, 10:13am
2
You have to send the workspace loaded gcode to your machine (if you are connected with wifi).
“send gcode to machine” is the button on the top right side of Luban.
Edwin
February 20, 2021, 10:31am
3
Not quite sure about your question, but I see you have loaded the G-code to the workplace already.
Hi all thanks for the response Edwin this worked
i am so relived
thanks
