Hi! I’m trying to engrave my first image with the laser, but I cannot see the image once i open up the workspace. It shows that my G-code was created successfully, and that it’s selected to preview, but nothing shows up on the grid. I used the test to also write something with the image, and it showed up just fine. The image below is what I’m seeing. Can anyone help with what I’d doing wrong?? Thanks!
Often a trap for newbies. Your image may be just out of sight…have you zoomed out on the workspace
Doug
Doug, I have tried zooming, and still nothing there. And when I use the text function, it showed up and engraved just fine, but the image didn’t show up at all
@tyler2786 Upload your files to the forum or a one click hoster.
- model or picture
- gcode
Which mode do you want to laser engrave? (b/w, grayscale or vector?)
Hi guys,
Has anyone found solution to this issue, I am having the same problem. File is generated successfully and I am able to run the job but the image does not show up on my Workspace. Created greyscale image.
Try the latest Luban from the Forum.
