I created a laser job in Lightburn with 40% laser power for the 10W laser. The GCode that comes out is correct:
M03 P40 S102
When I run this on the touchscreen controller, both the status screen, as well as the manual power override scale when swiping, show 45%! I tested some other power settings, and the touchscreen consistently shows higher values as compared to the GCode.
Has anyone else this effect? And: Any idea to find out if the touchscreen is right and the laser fires with more power than GCode says, or if it is just a wrong display and the machine adheres to the GCode?
