Laser engraving
Hi, @TechnewszoneAll you need is an image, then use Snapmakerjs to convert it to gresyscale then generate GCode to do laser engraving.
About the Snapmaker Showcase category Check this out.
Tips:
  1. Please be sure you choose greyscale mode. https://manual.snapmaker.com/laser_engraving/generate_g-code_using_snapmakerjs.html
  2. Follow this to focus laser https://manual.snapmaker.com/laser_engraving/set_the_laser_power_and_choose_a_way_to_engrave.html
  3. Last but not least, try different wood
@poundteam We implement Dithering algorithm to generate Gcode. All you need is an image. These two images have been tested.
samurai
