Hello everyone,
Have any of you ever tried to engrave lego bricks with the laser?
and if so, what settings did you use to engrave them.
thanks in advance
Hello everyone,
thanks in advance
It would be a good idea to do some tests, but be very careful and ensure you have exceptional ventilation. Lego bricks are made with ABS, and will likely release styrene into the air. I would suggest starting at a low power, maybe 1000mm/m for speed and go from there. You didn’t specify which laser you were using, but maybe start at 15-20% power for the 1.6W or 5-10% for the 10W.
I am using the 1,6W laser
