The entire system and Klipper crashed, and it can't be restored...
Earlier, I flashed a third-party firmware to make it work with the ACE PRO, and saw there was a new version yesterday, so I updated it. After the update, Klipper showed an error in Fluidd. I then manually reset it to factory settings. Finally, the printer got stuck on the boot screen, and Fluidd shows “unknown…”
How can I reflash the entire Klipper system now?
: I tried uploading the official firmware in firmware-config, but it failed halfway through with an error.
First: copy the FW on to a USB drive and stick that into the printer. Then start the printer. It depends on what you get there, but I take it you can click upper left corner on the screen and select FW upload.
Successfully recovered to normal. Thank you.
Just curious about what you saw/did and if during the bootup with the USB stick in the back did you get a prompt to select the USB or did it find it on its own. I’ve never had mine crash with the 3rd party on it but since the normal method is to do it from the properly operating menu screen I wondered what you might see if it wouldn’t boot up.
