Job repetition upon finishing it
Hello, I often use a CNC machine for drilling instrument labels and milling holes in boxes, which only takes a few minutes. After each, I have to find a file for the given job in the menu and go through all the steps to the start button. I would very much appreciate if in addition to COMLETE, the button to repeat the work was displayed on the touch screen of the device when the work is completed.
I would surely use this function even on 3D printing and Laser engraving jobs.
Using a computer for this purpose is impractical for me because it is located in another room.
Thank you.
If you have very short operating times per file I guess a PC connected via USB, running Luban, where your mouse is over the “run” button and you just click once after each operation would be the easiest solution.
Thank You for answer,
but it doesn’t solve my problem, because PC is not in the same room,
and when i do CNC job a usually use vacuum cleaner.
Nobody is particularly happy with the touch screen for this and many other reasons.
expect verrrry slow progress in improvements on it. its actually worse now than it used to be in some ways.
