Repeat function for Laser
The “Repeat” button on the screen after the laser is finished is sorely lacking. So that there is a “Repeat” button next to the “Complete” button. I often engrave or cut through the same files. I mark a place for the material on the work table, and every time I put it there and the laser does not need to be moved. And when I’m done, I have to press 8 different buttons to engrave the same thing. It would be very convenient if there was a “Repeat” button, which starts the previous file with all the previous characteristics.
I don’t know if this has already been asked. Perhaps there is already a solution to this question. I would be grateful if someone could explain this to me.
I will be grateful for help.
If you print from Luban this would be the shortest work flow, I guess (because of saving the open file and setting the focus).
Open a firmware request and maybe it gets into developement:
