Issue with 3D Printing from one Part
Good Morning,
i am on this Project: Star Wars Stormtrooper Universal/Intergalactic Cellphone Charging Stand by ray4510 - Thingiverse
I already printed successful 3 from 4. But the last one will not work. The Printer makes crazy things. I mad a video from it: OneDrive with Video and G-Code
I try also different settings in Luban. Normal Quality, High Quality and then Modified High Quality. The G-Codes from HighQuality and the Modified High Quality is in OneDrive.
I have the Snapmaker 2.0 A350. I am Using Polymaker PolyTerra PLA Cotton White.
The other 3 Parts was printed without issue.
I hope i forget nothing, if yes tell me i try to deliver the missed Information. :slight_smile:
I hope you could help me and tell me what i made wrong or if the last part is not printable.
Thanks & Best Regards
You have no supports in the holderTupper.gcode, so your printer is trying to start some lines in thin air. From the video you posted, that’s the problem I see.
It does look like you have supports in the Mod version of the gcode, so that one should work. I’m curious if you have a video from the attempt at printing that?
Good afternoon,
i think i fix it. I made again a calibration from the Bed, but not the Standard one with 3x3, i made it now with 5x5. And what should i say. The Mod Version was printed now successful!
@nivekmai Thanks for your answer, the first print with the Mod Version was looked like the video without the support. I think the issue was the calibration with 3x3.
