Imploading/Shrinking on some prints
Hi i’m seeking help in trying to determine whats the probable cause for inconsistency in the overhangs?
not ok prints
kinda ok prints
<redacted, image limitation>
these are off the same plate, same temps,
im using generic profiles btw.
didnt change anything from the default settings. This alo occured ine one file that i have
wasn’t able to nail down where in the plate it occurs but the behavior is pretty erratic.
Any help would be appreciated.
Thank you
i found a trend btw, all of the issues where happening on the right side where there was no fan.
these were closest to the fan
Yes, PLA isn’t great in enclosed printers. Keep the door open (but beware that draughts can result in warping).
It is also necessary to ensure a layer has long enough to cool before the next layer is started – a problem for small models or layers with a small cross-sectional area. This can be combatted by setting a minimum layer print time in the slicer settings (I suggest 20s).
