Make sure you’re using filament change which uses the M600 command, you’re on the latest firmware that supports M600, and add Cura post processing scripts.
You posted this in the Luban section of the forum though, so you would have to manually insert the M600 commands in the gcode file as Luban does not have an interface for adding pauses.
