File Locations with Luban Software
Hi I have just gotten my A350 and installed the Luban software. Can someone tell me how to set the default file locations in the software for the input and out files that Luban uses? My first attempt at creating G-Code put the resulting g-code files in a hidden folder under “C:\Users[username]\AppData\Roaming\snapmaker-luban\Tmp” and made it very hard to find the G-Code files. I had to search my entire computer for the “*.gcode” file extension to find it. There should be a Default File Setting that allows you to change your file locations for the software.
Unless something has changed recently I thought the “export gcode” button prompted you to pick a save location.
Export G-code to File → Choose a location → Save the file
The OP asked to change “the default file locations.”
I have the same question.
Ever since I upgraded to Luban 4, the export directory seems to always default to my Downloads folder.
Prior versions of Luban seemed to “remember” the last export directory you selected.
Has anyone else experienced the same problem and possibly have a solution? NOTE: I am using the Mac version of Luban.
if I do an import object from the file menu it remembers where I was and brings it up.
but, If I click on the folder it always takes me to same place Irregardless of where I last loaded a file from. Somewhere Luban has stored an address and I can’t figure out how to change it.
Yes, that happens to me too. A bug request was posted on github a while back and the devs say it will be sorted in a future patch but have not said when :frowning:
See: New 3D project, directory path issue · Issue #1518 · Snapmaker/Luban (github.com)strong text
