How do I clamp CNC material with little to no border?
I want to mill a design into a block that will have little or no boundary around the design.
My previous CNC machine had clamps that held along the bottom, the SM holds from above.
Has anyone found a good way to clamp lower down a block to keep it from interfering with the tool? I suspect I’ll have to jury-rig a horizontal clamp on the sides of the material, then clamp THAT to the bed somehow…
I’ve done a couple runs where I got the clamps to hold on the very edge of the corner of the material and in one case where I did the run in two phases, clamping on just one side and then moving the clamps to the other side. It kind of worked, but if someone has a suggestion for holding down from the sides or bottom, I’d also really love to hear about about it.
There is a thread from @jepho about some clamping systems. I can’t find it right now but I guess he will show it to you, or you do a bit of searching in his threads.
As @xchrisd mentioned, @jepho has several good posts about it.
There are some other goods posts too. I’m considering the low rise clamps in
Thanks @xchrisd. Happy to oblige. There you go. :slightly_smiling_face: :+1:
https://forum.snapmaker.com/t/a-disaster-in-the-making/
There are some cam lock jigs some people have made and used like this:
Haven’t gotten around to making one personally.
I’ve managed to get by with holding onto the very edge and corners as StumbleRunner did. I use either some scrap plywood ‘fingers’ I cut or some ones I printed out of PETG and PLA. That way if (when) the bit runs into them, it just cuts through them and doesn’t break.
I’ve also had pretty good success doing one end then the other. There is a noticeable tooling pattern at the intersection point, but nothing that I wasn’t planning on sanding out anyway.
Other people have had success with:
double sided tape
blue tape on both the work piece and the spoil board and then super glue together
hot glue gun around the base
Oh, I like that cam clamp idea… might need to try and make a modified version of that so that I can still anchor the material when it runs really close to the edge of bed.
Yeah, exactly - I think that cam clamp is in my future…if I can get the 3D printer module to behave.
Thanks all - for links, and for the excellent previous contributions!
I got it to work by just shrinking the design and holding on to the edges with two clamps, but I expect to be doing enough small or borderless stuff that I’ll definitely be figuring out a more permanent solution.
You can also use plywood and cnc to make cam clamps.
