Hey everyone — hoping someone has run into this and found a fix.
Setup:
- Printer: Snapmaker U1
- Slicer: Snapmaker Orca V2.3.3 (Full Spectrum Beta)
- OS: Windows 11
The Problem:
I exported 15 filament profile JSON files from OpenSpool after building out my NFC tag library. When I try to import them into Orca via File → Import → Import Configs, I get the following every time:
“There are 0 configs imported. (Only non-system and compatible configs)
Hint: Make sure you have added the corresponding printer before importing the configs.”
This happens whether I import a single JSON or all 15 at once.
What I’ve Already Tried:
Fixed the
compatible_printersfield — Originally the JSONs had"compatible_printers": ["Generic PLA"]which was wrong. I batch-edited all 15 via PowerShell to match the correct printer ID extracted from the printer bundle export:"Snapmaker U1 (0.4 nozzle)". Confirmed the field is correct in the files. -
Fixed the
inheritsfield — The JSONs originally had"inherits": "Generic PLA". Since there’s no Generic PLA base preset in Snapmaker Orca to inherit from, I batch-edited all 15 to"inherits": ""(blank). Confirmed via Notepad that the change took effect. -
Moved files off the filament directory — Tested importing from Desktop in case Orca was rejecting duplicates already in the user filament folder. Same result.
Tested single file import — Isolated one JSON, confirmed it looks structurally identical to working user presets already in the filament folder. Still 0 configs.
What a Working JSON Looks Like (for reference):
The pre-existing working presets in AppData\Roaming\Snapmaker_Orca\user\default\filament\ follow this structure:
"type": "filament",
"name": "Eryone PLA ERYONE Galaxy",
"inherits": "",
"from": "user",
"instantiation": "true",
"filament_vendor": ["Eryone"],
"filament_type": ["PLA"],
"compatible_printers": ["Snapmaker U1 (0.4 nozzle)"]
The imported JSONs now match this structure exactly — yet still fail.
What I Haven’t Tried:
- Whether the printer ID Orca uses internally differs from what appears in the bundle export header
- Whether Snapmaker Orca V2.3.3 has a known bug with filament JSON imports
- Whether the
"from": "user"field casing matters (lowercase vs capital U)
Question:
Has anyone successfully imported custom filament JSON profiles into Snapmaker Orca V2.3.3? Is there a specific field structure or naming convention that Snapmaker’s build requires that differs from standard OrcaSlicer?
Any help appreciated — this is the last piece of getting my full filament library dialed in.
Thanks
— BlackOps
