HELP PRINT luBAN
HELP!!! Snapmaker A350 printer! Problem printing on luban and setting up printing a model with holes! No matter how much I set up, I can’t get the model below to print.
We would need more details, especially about the model you want to print.
Best would be to upload your STL file here that someone can check your model structure.
And we need to know which print settings you are using and which material
And you say “i can’t get the model below to print” - did you want to attach something here? Because there is nothing “below” in your post.
What exactly happens if you try to print? “can’t get it printed” is unfortunately to general, we will need to know what exactly is not working
