Help provide medical masks: (probably should make sure your local hospital is willing to use them.)
It is possible to print a 90% size (small) mask on a Snapmaker 1.
https://longliveyoursmile.com/3d-printable-mask-for-covid-19/
If you turn the mask right on the buildplate also 100% are possible
Hmm, I rotated it, but couldn’t get it to fit until scaled down to 90%.
hey, i tried again with snapmakerjs, it works 115,8mm x 115,8mm x 57,9mm
By the way, where to get the filters from?
Filters - read the instructions page from the website.
It’s also been mentioned that T-shirt material is a not-quite-as-good possible substitute.
Thanks for providing the design file. We are currently working on designing a medical mask as well. Thing is there are a lot of factors to consider.
Filter information
There is something big going on:
Original can only make the chin item (or glue the top together) but everything helps!
