"Heated Bed Temperature Abnormal" - Error Code: 0003-0526-0000-0000 - Resolved
MCU ADC out of range — caused by debris in feeder ribbon cable connector
I encountered an issue with my Snapmaker U1 after servicing the filament feeder. The printer reported a heated bed temperature error, but the actual problem turned out to be a contaminated cable connector inside the feeder.
Symptoms
After reinstalling feeder (slot 3, 4), the printer failed to start normally and displayed:
  • Error code: 0003-0526-0000-0000
  • Error message: Heated Bed Temperature Abnormal
  • Klipper error: MCU 'mcu' shutdown: ADC out of range
In Fluidd, both temperature readings were exactly -1035.805°C:
  • heater_bed: -1035.805°C
  • temperature_sensor cavity: -1035.805°C
Restarting and power cycling the printer did not resolve the issue.
The error depended entirely on which feeder was connected:
  • Feeder 3/4 disconnected: Printer started normally, with correct temperature readings.
  • Feeder 3/4 connected: The temperature error appeared immediately.
  • Feeder 1/2 installed in the 3/4 position: No error.
  • Feeders 1/2 and 3/4 swapped: The error still occurred when the problematic feeder was connected.
This confirmed that the issue followed the feeder module rather than the printer’s connector or the heated bed itself.
Cause
After disassembling the problematic feeder, I found two PCBs connected by a flat ribbon cable:
  • SPD-0041-V1.1
  • SPD-0042-V1.1
The ribbon cable uses FFC/FPC connectors with flip-up locking tabs (ZIF-style).
Inside the ribbon cable connector on the SPD-0041 board, I found a tiny piece of debris which caused problem. It looked like dried grease from feeder gears (AG4 Battery for scale):
Solution
  1. Turn off the printer completely and disconnect it from power.
  2. Remove the affected filament feeder.
  3. Open the both feeder housings to access the two PCBs connected by the flat ribbon cable. Bottom part is held by screw inside and two clamps at sides:
  4. Peel back the black fabric tape securing the ribbon cable connectors.
  5. Lift the locking tab on the FFC/FPC connector. Do not pull the cable out while the lock is closed.
  6. Carefully slide the ribbon cable out.
  7. Inspect the cable contacts and the inside of the connector for debris.
  8. Remove any debris.
  9. Reinsert the ribbon cable in its original orientation, making sure it is fully and evenly seated.
  10. Close the locking tab, restore the protective tape, and reassemble the feeder.
  11. Reconnect the feeder, start the printer.
In my case, after removing the debris and reconnecting the ribbon cable, the printer started normally without the temperature error.
Despite the error indicating a heated bed temperature problem, the actual issue was associated with the filament feeder’s internal ribbon cable connection.
I cannot confirm whether the debris itself caused an electrical fault or whether reseating the ribbon cable restored a poor connection, but the problem disappeared after cleaning and reconnecting it.
I couldn’t find this troubleshooting step in the official Heated Bed Heating Anomaly guide or anywhere else, so I’m sharing it in case someone encounters the same error - especially if problem disappears while one or both of feeders are disconnected.
I’m going to tag this as a bug, because of the misleading error code report.
@Furren
Thank you for your feedback. I’ve forwarded it to the engineering team, and the wiki support team will add this scenario to the troubleshooting guide.
Best Regards.
