https://snapmaker.github.io/Documentation/gcode/G026 says that “G26” is used to print a “mesh validation pattern”. When I try to run it from a terminal after an 11X11 level, I get an “unknown command” error.
Am I missing something?
That’s because they copy/pasted the Marlin documentation with few updates. G26 isn’t available, as the firmware is compiled without G26_MESH_VALIDATION
Darn. Probably no way to enable G26_MESH_VALIDATION, recompile and feed it to the SM I imagine.
Thanks.
It’s not hard, but why? It’s easy to spot check the mesh using G42 at the control points, and if you want a single layer print slice the 25mm test cube scaled up as big as you need and delete everything after the first layer in the file.
That’s too easy. I’ll give the cube a try.
I think technically G26 uses a sparse first layer to speed up printing. I wonder in Cura if there’s a way to get the first layer skin to be <100% fill. I feel like there is but I’ve never tried.
