Available Gcode commands
I am wondering if it is possible to add gcode commands that don’t appear to be available in the SM 2 software, specifically G02 & G03 (circular interpolation). In addition to providing smoother curves, it would also considerably reduce the lines of code and hence the file size.
Thanks
Those two specific commands are being worked on, apparently: Snapmaker Marlin "G3"?
Aside from the existing ticket to work on that, the firmware is open source on github: Snapmaker · GitHub
There are several threads on the forum about the process to compile and package the firmware. Just be aware that you could brick your snapmaker.
Thanks for the information. I will check it out. I didn’t realize it was open source. If someone has already modified the firmware it would be worth considering especially if has been tested.
G2/G3 is in the firmware version I’m using (old), and I don’t think it ever was removed.
It is defined here:
I think the issue raised in the repo is not about adding it, it’s about someone experienced a weird quirk causing it to move slowly. Personally, I haven’t experienced that though, it works fine when i need it.
It looks to be something interesting to experiment with, but might require additional knowledge of the hardware capabilities. Another reason I would like to see additional commands is efficiency which often speeds a process. Perhaps the hardware is a limiting factor.
Thank you for the help.
G3 and G2 has not been supported yet.
Please refer to this G-code sheet posted by @parachvte
@brent113 i know this thread is old, but is arcing supported now? You were saying how it works when you use it, then Edwin (miss you dude) said it wasn’t supported yet. I’m confused lol.
Similar backlash compensation, there appears to be a range of values that causes issues. Large circles seem to work well, small circles tend not to. It’s all very strange.
As far as I’ve seen the developers haven’t done anything with this.
@Artezio Currently, it still does not support G02& G03, but they will be supported later. Thanks
@Tracy is there an anticipated timeline for when this will be supported? Are there other commands that are being worked on for 3d printing or otherwise? (specifically hoping for power inline for the laser)
We have updated the G-code commands for all machines, which you can check out here: G-code References | Snapmaker Wiki. If there are any commands you think should be added, feel free to suggest them in the comments.
