Fusion360 - how do you save/export the file
hi everyone, was trying to use “post process” at the end and just found out they changed it to the NC program…
so if anyone knows, how do you save/export the file from fusion 360 so the snapmaker recognises it?
edit - did a tutorial for the NC program https://forum.snapmaker.com/t/using-fusion-360-how-to-use-nc-program-snapmaker-2-0/27444
Change the file type to .cnc.
hi sdj :smile: long time no see - you helped me a lot when i was first using the snapmaker, had a seizure and had to learn to walk again, so getting back into the swing of things.
