just started playing around with the laser and ran the first time setup. I’ve the enclosure and was wearing safety goggles all the time. It is hard to see anything happening then, because the whole procedure gives you no chance to turn the lights on in the enclosure. Can you change this for coming users?
You probably have an old firmware version. You should upgrade to at least 1.9, on mine there was 1.7 (or so) at delivery which had no support for the enclosure.ware version. You should upgrade to at leat 1.9, on mine there was 1.7 (or so) at delivery which had no support for the enclosure.
Have been on 1.10 past then (and am still). But ´just to check: Have you, when you went through the first-time setup with the laser module (i.e. when you for the first time attached the module), been able to swipe and control the enclosure?
