Filaments: Support for ABS, TPU
Hello.
Question 1:
I have a cover installed and I’m printing a lot of ABS. I decided to try printing the interface layer using “Oak lab” Support for ABS, but there are no corresponding profiles in SnapmakerOrca or the printer itself. Please provide instructions on what settings should be used on the printer and in the slicer.
Question 2 (bug):
In the printer settings, you can select multiple Generic TPU profiles. However, there is only one profile available in Snapmaker Orca. Therefore, when printing TPU, you cannot use the filament settings from the device.
What you need to do is set up your own filament profile, See here: Printproblem on new U1 - #9 by ColdCoffee
I was able to export the necessary filaments from the original Orca Sliser.
Thank you, but this does not solve the second issue. U1 has several TPU profiles in Generic, but installing any of them does not allow you to use the filament as Machine Filament in Snorca.
For the second one, I think it is more like a software feature gap or incomplete device-software sync, preventing users from accessing the printer’s built-in TPU presets.
Can you post a feature request here? I’ll bring it to the software engineering team to check whether it is on the plan?
