FEATURE REQUEST: Recover GCode from SN2.0 screen
Good morning!
Feature request: In “files” app, under “long press” menu where you can currently rename or delete a file, add an option to copy the file to USB.
User story: I had a print fail because the filament jammed in the nozzle. I have the skills necessary to edit the GCode to start at the z-height of the failure and successfully finish the print, but I didn’t save the GCode after I transferred it over WiFi to the Snapmaker. If I could load it on to the flash drive and pull it back, I could edit it and save my print.
Thank you!
I purchased some used machines. They have G-code file on them and I would like to keep them for future reference.
