Fan guide for single nozzle print head
My print head’s fan guide is warped after a bad print that caused ABS to badly choked the print head including the fan blower guide. While I managed to clear the abs and got it working again, the fan guide is warp. Am looking for the stl of the fan guide so that I can print a new one to replace.
Anyone knows where I can find the stl? Thanks lots.
Why not upgrade it while you’re at it? :stuck_out_tongue: I’m currently using this one on my snapmakers;
Interesting. Mine is A350 not A350T though.
Will look into this to see if it fits :-).
Thanks!
The only difference between the A350 and A350T are the quieter linear rails. :upside_down_face: The print module is exactly the same.
Hmm, afraid my Single Nozzle Hot End does not have the front fan air intake slits.
But I realised that the difference is just an additional ducting cover that the Embrace Making video showed. I will print one and see if it is better :slight_smile:
Have also left a request ticket at snapmaker support - see if they will help as I have this set since 2010 but did not open and use it till this Feb.
Thanks
2010 :astonished_face: I think not.
First gen of the printing toolhead, they didn’t make those long, kickstarter and early adopters. I have an A350, but it came with the V2 head. You might be able to get the shroud from support.
