I wrote my own adjustment procedure that is, IMHO, even more complete, My procedure. Using my method, it only takes a few minutes (once you’ve removed the assembly from the linear module) to adjust the cam and, once adjusted, doesn’t change while you are (final) tightening the screws. My expertise comes from being a calibration tech in the aerospace industry for 50+ years.
BrianS
52
Related topics
| Topic | Replies | Views | Activity | |
| xy axes rock very loudly and rattle | 71 | 884 | April 15, 2024 | |
| Shoring up the CNC module | 33 | 3247 | February 9, 2023 | |
| "Bump" in Y-axis | 88 | 8391 | September 21, 2023 | |
| Need support: linear module play | 16 | 1737 | July 15, 2020 | |
| Loose Linear Module w/ Workaround Attempt | 20 | 2605 | November 17, 2020 |
