Ethernet Connectivity
Oh really! I’ll try it again.
It may have been quietly enabled with 1.0 firmware and you’re the first to try it. :sweat_smile:
Thanks for the confirmation! :folded_hands:t2:
Another thought, isn’t your U1 a presale unit? That might account for Ethernet not working with an USB ethernet adapter.
I just haven’t tried it again since probably v0.9.
Can you share which USB-to-Ethernet adapter are you using. Assuming that not all chips will work.
This one is supposed to work. Ordered but returned since my WLAN works perfect. (LAN mode only) Amazon.de
Thanks for the quick reply. Did you use this with a USB C to USB A adapter?
You do need that adapter, indeed.
I used the LevelOne USB-0401 dongle, which I happened to have on hand. Everything worked perfectly fine with it, even with the latest firmware. However, I did encounter one problem: the firmware can only be updated via Wi-Fi, as the printer doesn’t recognize that it’s connected to the internet via the dongle…
