Hello support/Tech, i run a project carve a lion head out, i use EstlCam to make the code, i make 2 runs, one rough with 1,5mm endmill, an one cleanup with carve bit…
The code was made in same time, ie dimension aso all the same, just run it as 2 steps for change of bit.
The roughing went flawless(22 hour), but the cleanup went wrong at about 70% finish, so the 2 run started the right place but later it run its own way and started carving 20-30 mm to the right of the carve area, nothing break lucky me, but the job was lost…
Why did that happen, i check the code on NCviewer, and it looks fine, no run off in right side?
I have the Gcode and the if the snapmaker TECH wanne see whats going on, it must not happen, it must follow the gcode or it useless… but i hope TECH can help out here…
Tommy
