Enclosure Cable Clips
Does anyone have the specifications for the cable clips that clip into the rails to hold the cables? Looking to print some to modify to hold some tools. Thanks
You mean these? If not, you can always ā€œ3d scanā€ objects using a regular printer scanner to get pretty dimensionally accurate objects:
  • scan the object alongside a ruler (e.g. put the ruler on the scanner bed next to the object) on as many faces as necessary to get a good representation
  • pop the scans into fusion 360 on the correct axis (import > image)
  • calibrate the images to the ruler
  • do a couple intersect extrudes from the various faces
There’s a couple Youtube videos out there going over this process too.
No the ones that clip into the rails to hold the cables…
