DXF Files to large
I have a DXF file to cut leather but it is too large for the cutting area. How do I only cut certain parts of the image?
I generally break large objects apart in the source tool, and export them individually. I’m not personally familiar with DXF files, but where ever you created it probably has better support for that sort of changes.
I purchased the pattern so I don’t have a source software.Thanks for the reply though.
If you happen to own Lightburn, it allows you much better selections as compared to Luban.
If you do not have Lightburn, then you need a program that can modify DXF files - it seems that InkScape can do that (never tried myself).
