Dual extruder tutorial
Hi there,
I am looking for a small tutorial how to use the two extruder heads at the same time to duplicate a model. Anyone that can support in this?
Thanks in advance. Jeroen
did you check the Selecting the print mode of J1 | Snapmaker Wiki
This can be done a number of ways.
In Luban slicer, print mode can be selected and i believe most of the rest will be taken care of
In other slicers, adding the M605 command to your start G-Code
Here’s the Marlin page for the use of that code. You can choose to do copy or mirror mode depending on what you add onto the M605 command.
Hope this helps, feel free to reach out if you need any help
