Discussion of Snapmaker Ray Firmware Updates
This thread is for discussion of the Snapmaker Ray Firmware Updates.
CAN hub not working in V1.6.5. I am using a Snapmaker CAN Hub so that I can use the air purifier and emergency stop button on my Ray. In V1.6.0 it would allow me control of the air purifier and the use of the emergency stop button but in the latest version the controller will not start up and will continue to restart over and over again and eventually it might recognize the emergency stop button but then I can’t control the air purifier. The air purifier and emergency stop work fine if they are plugged directly into the add-on port but I want to use both at the same time, that is why I purchased the CAN hub. I don’t want to downgrade the firmware as I have already run into the issue where the laser doesn’t turn back on after clearing a flame exception.
I encountered issues after upgrading the firmware to V1.6.5 with my Ray. The device started to malfunction by exceeding the designated boundary area. However, the problem was resolved when I reverted back to the previous version, V1.6.0.
Hi
I bought a new Ray one week ago and wanted to update the firmware. Have downloaded it but Luban asks for 2 firmwares: one for the controller and one for the module
Which one shall I update ?
Thanks and kind regards
Franz
additional questions:
  1. Luban does not tell me the current version - how can I find that out ?
  2. Shall I update to 1.6.5 or to 1.6.0 ?
Franz
Sorry,
I have just seen there is another dialoque for the firmware in the workspace area.
I have already version 1.6.8 – is this the recommended version at the moment ?
Many thanks again
Kind regards
Franz
Here you go:
many thanks
kind regards
Franz
Hello,
I’m trying to update the firmware of my Ray using the SD card method Updating the firmware of Ray | Snapmaker Wiki but i do not have any luck:
  • I’ve downloaded the .bin file from the Support site
  • wrote this to my SD card
  • shut down Ray completely, inserted SD card and restarted the controller
The controller shows a white ring around the button and then turns red / green but is never blue…
Could anybody help me please?
Hey, did you ever find a fix for this? Having the exact same issue. Has something to do with the SD card not reading correctly, but I deleted the firmware and it still won’t read correctly.
the support told me to use a update.bin file.they provided - in fact that was only the same file with the name update.bin .
So try to rename the firmware image you can download from the wiki…
But: no guarantee otherwise contact the support to be sure :slightly_smiling_face:
