Different Infill Settings on separate object?
Hello, I have a shape that i’d like to print hollow, and a cylinder object attached to the shape that i’d like to be 20% infill.
Is there a way to individually set the infill settings in Luban?
Thanks!
No.
Have to use Cura or Prusaslicer or Simplify 3d
I’m kind of curious what the use case for this is…
  1. Some parts of a design, or separate objects need different fill for differing strength requirements…Usually for engineering, not toy, jobs.
  2. I’d like to print sample blocks for each of the infills, but don’t want to submit 26 different print jobs/service the printer 26 times. I’m okay with having to right-click and select the fill.
With Orca Slicer, you can assign a different fill to each object, and with the modifiers, even within the same object.
You’d think that using different profiles for different objects (where you select different structure settings for each) would do that, but… no.
Luban slices the entire contents of the cube in a single go, and with a single configuration. You can fine-tune the heck out of everything, but what it ends up with is:
1 - a single STL generated by combining the results of whatever you do in the workspace (positioning, resizing, merging, whatever). This is true even for dual-extrusion heads: the models are combined into a single STL, with each extruder’s part marked so the slicer can split between extruders.
2 - a single configuration file with all the slicing settings for that one STL, the general machine settings, and extruder-specific settings if applicable (nozzle size, temperature, etc)
These 2 files (3 actually, there’s a fixed configuration block) get sent to the slicer in one operation. Since that configuration includes blanket statements like “This model has a 15% honeycomb infill” or whatever, it’ll apply to everything. Virtually (or actually) sending per-model configurations in a single operation would be a very significant change to Luban, and it’s unlikely to ever happen (even if Luban was still being updated) so… yeah, use SnOrca for that :slight_smile:
