I am trying to create a custom macro in Luban v4.0.1 (following the bed leveling calibration forums) but every macro I create will not execute. The predefined macros appear to work just fine. As a test, I copied the M1007 macro contents and pasted it into a new custom macro:
But when I try to run the macro, nothing happens. When I edit the macro, the “Repeat” field is blank:
If I update the value to 1 again and save, the value is still not stored correctly. Instead, the value is 0 after this point. No amount of updating/saving a non-zero value seems to fix it.
I suspect the “repeat zero times” logic is what is preventing the macro from running and the actual bug is that Luban isn’t saving the repeat value correctly. Has anyone else experienced this?
