Cura not honoring initial layer temperatures when printing on A350
Hello,
I have been tinkering with Cura and couldn’t help but notice that although Cura has boxes to enter initial layer temperature for both the nozzle (material) and the bed, it doesn’t seem to actually use them.
Evaluating my pre-print Gcode settings vs Cura’s variables, I thought that perhaps I needed to add _layer_0 after my variables to accomplish this, but it doesn’t seem to like it very much.
I tinkered with it a bit further last night so its possible that I have it resolved now, but can someone please look at this and tell me what, if anything, I am doing wrong?
I went ahead and pulled _layer_0 from the print bed temperature because it kept trying to set it to 250 degrees instead of the variable I assigned.
The reason I would like to do this is because I am having issue with this particular filament sticking to the bed, so I want to start off at a higher temperature then tone it down to where it prints nicest at.
PS shouldn’t initial layer settings also apply to skirts, brims and rafts?
;M104=print temp, M140 = bed temp, 109 = print temp wait, 190 = bed temp wait
M104 S{material_print_temperature_layer_0} ;Start heating bed
M140 S{material_bed_temperature} ;Start heating extruder
G28 ;home
G90 ;absolute positioning
G1 X-10 Y-10 F3000
G1 Z0 F1800
M190 S{material_bed_temperature} ;Wait for bed to reach temp before proceeding
M109 S{material_print_temperature_layer_0} ;Wait for extruder to reach temp before proceeding
G92 E0
G1 E20 F200
G92 E0
Not really sure. Here’s my Cura startup code. Looks basically identical.
M140 S{material_bed_temperature_layer_0}
;Enable Backlash Compensation
M425 X0.02 Y0.02 Z0.02 F1 S0
G28 ;Home
M190 S{material_bed_temperature_layer_0}
G92 E-1 ; Prime
G1 E0 F200
Sounds like your build plate temperature initial layer is set at 250C to me
It sounds like it, but its not, it was set to 85 hehe.
Ill try it again, maybe i had transposed something poorly.
What do the first few lines of the generated gcode file look like that set it to 250C.
Don’t need the whole file, just the initial gcode Cura generated.
I’m not aware of a bug in the firmware that sets temps to 250C.
;Generated with Cura_SteamEngine 4.7.1
M82 ;absolute extrusion mode
M104 S75 ;Start heating extruder
M140 S250 ;Start heating bed
G28 ;home
G1 X-10 Y-10 F3000
G1 Z0 F1800
M190 S75 ;Wait for bed to reach temp before proceeding
M109 S250 ;Wait for extruder to reach temp before proceeding
Maybe I had my 104 and 140 swapped around it looks like?
Let me try again tonight with screen shots of the settings in cura if it isnt working vs the gcode
It had set both the extruder and the bed to 250. Maybe it set the extruder to the 250 it happened to want because it was under a minimum value?
I will go back in and put the layer zeros back in too. It was kinda late I guess.
Yea looks like in the process of making changes something got crossed up. M140 is bed, M104 is extruder.
OK, lets try this again!
Cura precode:
M104 S{material_print_temperature_layer_0} ;Start heating extruder
M140 S{material_bed_temperature_layer_0} ;Start heating bed
G28 ;home
G1 X-10 Y-10 F3000
G1 Z0 F1800
M190 S{material_bed_temperature_layer_0} ;Wait for bed to reach temp before proceeding
G92 E0
G1 E20 F200
G92 E0
Parameters:
Gcode Snippet itself:
M104 S250 ;Start heating extruder
M140 S85 ;Start heating bed
G28 ;home
G1 X-10 Y-10 F3000
G1 Z0 F1800
M190 S85 ;Wait for bed to reach temp before proceeding
Snapmaker:
Everything checks out… I think my machine was acting up last night because it kept rejecting my parses etc, seems like everythings in order now.
Hopefully someone may be able to utilize the information presented anyhow.
Thank you!
@brent113
Can you tell me what your G92 E1 does? I have E0
You said Prime, what is it doing exactly?
Before my prints start, it craps out a string with tends to loop and then hooks on the side of the print plate before printing. Unraveled its probably about 6" long or so.
More curious than anything… I’d love to understand more of the things you guys do to end up with better results. Not just copy paste but understand :slight_smile:
G92 sets an axis to a position (E, extruder, is the 4th axis).
G92 E-1    ; Tell the machine the extruder axis is at position -1mm
G1 E0 F200 ; Tell the machine to extrude to E axis 0mm at 200mm/min feedrate
This extrudes 1mm of filament, and leaves the E axis at position 0, with 1 fewer line than you’ll typically see.
G92 E0     ; Zero out the E axis
G1 E1 F200 ; Move axis off zero 1 mm
G92 E0     ; Zero it out again
Your setting of G1 E20 feeds out 20mm of filament, a huge amount.
Leaving the E axis at 0 is essential in the prep code, as the first line of the print will read something like this:
G1 F1080 X123.241 Y159.373 E0.01787
If the E axis is left at a position of 20mm from the start gcode, and then goes to 0.01787mm, it will in effect retract 19.98 of filament, instead of the desired result of extruding a small amount.
Hmm I see,
Yeah I just kind of hobbled together the Gcode and the machine variables from various posts on the internet, kind of combined a few things I had read.
That makes sense and I will adjust to a lesser feed similar to what you have shown.
However, wouldn’t a longer pre-extrusion before printing improve the flow rate once it gets to the print bed and actually to work, or is that not really a thing? I would have assumed that it should be gotten nice and flowing before startin the job.
I guess thats what a skirt is for though.
In Cura I have a minimum skirt length set to ensure it will finish priming. In Simplify3D I just make sure there’s more than 2 skirts for small parts, since there’s no minimum length setting.
You run the risk of priming at the home position and having some drip out of the nozzle before arriving at the start of the skirt.
I retract 2mm at the end of the print, and prime 1 at the start of the next print making up the extra prime in the skirt, other people do other things - it’s easy to change and completely a matter of personal opinion. I recall sdj and atom do a combination of a priming line at the edge of the print area and a full prime at the start.
Single skirt usually does the job, 2 always does, but I do a 3 layer skirt because I find it’s easiest to remove. Doesn’t really take that much more time or filament. Most of the stuff I print is 150mm at the largest. If I was to print anything really big I might reduce it.
That’s on Luban though. Haven’t really gotten into Cura much. Have been doing a lot of cnc and laser lately. I know I need to make the switch but the stuff I had been printing wasn’t critical and Luban worked fine.
