Cura 1.5.0 for slicing
I’m trying to set up Cura 1.5.0 for slicing for the Snapmaker. I have a choice of Gcode flavors and not sure which is the most compatible with the Snapmaker A350. Choices are:
RepRap (Marlin/Sprinter)
RepRap (Volumetric)
UltiGcode
Makerbot
BFB
Mach3/LinuxCNC
TIA,Steve
Maybe start with these
Personally I don’t care for the start and end gcode they use, you should consider tweaking it. If you look around many people have posted their start/end codes they use.
Something like this: Cura not honoring initial layer temperatures when printing on A350 - #7 by MooseJuice
Just to answer the original question as phrased, the Snapmaker uses a Marlin dialect, so “RepRap (Marlin/Sprinter)” would be the most appropriate of the flavours on offer. The specifically-tailored profile is likely a better place to start, though.
