Hi to all!!
i use Snapmaker Ray and lightburn Software.
After the end of the job, the crosshair laser is switched off
How can is switch on??
(After shut off the Laser and swicht on the Crosshair is active!, but it is not very confortable)
So, I banged my head against this for a short while, as the command line they say turns on the laser didn’t work for me.
However, I found a much more convenient work around.
As you said, the crosshair is on until you do your first job and then it goes off.
All you have to do when you walk up to take the piece out is to push the laser head to the left until you trigger the end stop. It will beep at you, but when you pull it back, it will have turn the laser back on. It’s actually more convenient than using the command line because I can turn the laser back on at the same time that I’m moving the head out of the way to get my piece. (I have the enclosure, which makes getting larger pieces in and out a bit fiddly.)
HAHA, I just noticed this is from 2024, so hello from the future, I hope you found an answer in the last year.
