coroNET 2 - a physical companion system for Snapmaker U1
coroNET 2 is my open-source hardware entry for the Snapmaker U1 Innovation Fund. It is an ESP32-S3 companion controller powered by coroNET OS 2 that turns live U1 and Moonraker telemetry into a physical control and feedback system around the printer.
A compact Klipper screen
The dedicated 480 x 320 touchscreen shows live print state, progress, active tool, material, job time, four tool temperatures, bed temperature and chamber temperature. It gives the U1 a compact secondary Klipper telemetry screen without depending on a phone or browser.
Printer status you can see and hear
A 60-pixel RGBW system makes printer state visible from across the room. Users can choose from 336 documented animations across five groups, covering printer-status feedback as well as decorative lighting. The internal RGBW section can also provide practical white work lighting over the toolhead and build plate.
Status changes are not limited to LEDs. Every event can trigger any WAV file chosen from the microSD card, allowing each user to build a personal sound set for starts, finishes, pauses, errors and other printer states. Together, light and sound make it immediately clear whether a print is running normally or needs attention.
Automatic chamber and airflow control
In automatic chamber-target mode, coroNET 2 uses live chamber temperature and print state to progressively open a servo-actuated iris damper and regulate PWM fan speed. Deadband, smoothed output changes and configurable failsafe positions prevent unstable control when telemetry is missing or stale. More stable chamber conditions can improve consistency when printing engineering materials.
The airflow outlet can feed a user-built exhaust duct or compatible filtration system to help remove excess heat and manage printing fumes. A protected logic output can command an external chamber-heater controller without powering a heater from the ESP32, and coroNET 2 also includes network integration with Panda Breath.
Control from the touchscreen, phone or browser
The same controls are available through an Android companion and a responsive local browser panel served directly by coroNET 2. WiFi provides rich live control and the app can notify the user about errors and completed prints. BLE handles pairing and recovery. No cloud account or external server is required.
When the printer is idle, the status bar can become decorative room lighting and the touchscreen can switch to a configurable clock.
Built and tested by the community
This is working physical hardware, not only a render. @wlodeka confirmed clean mechanical compatibility with the original Snapmaker U1 Top Cover and demonstrated the internal work lighting. Bobby Morgan’s extensively customized installation shows the same coroNET controller platform running the previous OS 1 generation with environmental monitoring and active airflow.
coroNET OS 2 release 0.4.5 is stable, reproducibly buildable and available now. The source, printable parts, BOM, assembly guide, wiring documentation, firmware, checksums, USB Flash Tool package and Android APK are public under the MIT license. OTA updates include rollback validation, with SD recovery available as an additional recovery path.
Project, documentation and downloads:
Build gallery:
https://github.com/AlphaStudioDE/coroNET_OS_2/blob/main/docs/COMMUNITY_SHOWCASE.md
I would be glad to hear which parts of coroNET 2 would be most useful in your own U1 workflow.
snapmakeru1 #U1InnovationFund #coroNET2 #OpenSource #DIY
