Converter boxes and M4 x 30 screws not fitting
I received my package after a long wait on the 2nd of August. I started putting it together on the 5th. While putting it together I got stuck on step 18 of 22.
In this step we attach the converter to the machine. The only problem is, one of the two converters is faulty. To attach it you use 4 screws. 2 on each side. However, on one side the screws don’t go through. I have checked with all the screws in the bag. They work on the other converter but not this one.
On the 5th I sent in a complaint via email. On the 6th I was told two replacement converters would be sent to me. I thought why 2? Oh well at least It will solve my problem (I hope). I was told that they would be shipped out within a week and asked me to verify my address. I verified immediately and waited. I was also told that I would receive a tracking code once it’s shipped.
More than a week passes and no tracking number received. I receive an email saying the case is closed because the ticket was inactive for a week. I thought I’d send in another email for an update with “I hope you haven’t forgotten about me?”.
I got an apology and was told that their warehouse colleagues would send me new screws ASAP.
SCREWS? What?
I replied again - twice. Again referring to previous emails and the expectation of new converters as promised. Once again explaining the issue with more pictures.
This was on the 15th. I didn’t expect a reply immediately as it’s weekend there. But now the 17th and 18th have passed (monday/tuesday) and still no response after 4 full days. Still no tracking number and still an incomplete Snapmaker device.
I raised a question on why the responsiveness has been so poor and why I’m being made to wait even more than I already have without replies. I understand that they are busy, but if you’re struggling to assist people and don’t have the manpower after gathering revenues of over 10m USD… I think that needs some improvements with extra staff.
In case anyone is wondering who I was emailing - it was Edwin. Very respectful guy and seems to be doing his level best (as I can also see in the forums). BUT he clearly forgot about me and definitely forgot what he was meant to send me. I’m very disappointed and after reading the forums I’m not looking forward to dealing with all the issues people seem to have with the snapmaker and calibration.
Hopefully by posting here it catches the attention of Edwin and his team and they can finally send me the replacement part so that I can finish my machine and hopefully set it up.
I had this issue too, but the fix is easy. On the sides there are two small screws on each side. Don’t take them out, but loosen them slightly. You will be able to reposition the middle part (I just stuck the mounting screws in on both sides so that the middle part is centered and ensures the screws fit). Then retighten the small screws on the side.
Hi Twix, we apologize for the late response. I will have @Edwin here to help you resolve your case. I will also follow up with you should you have any further questions. Thank you :slight_smile:
Hi @Twix (Danish),
Thank you for reaching out to us.
Sorry for the typo in the previous emails. I will send you the 2 converters for replacement instead of the screws. I pushed my colleague to prepare the converters for you and other users.
The converters and another part belong to the same product code, if there is a separate delivery of the adapter to be unpacked, this requires a request from us.
If you have any other questions, please feel free to contact us.
Best regards
Hi, I have the exact same problem. Just assembled my new Snapmaker 2 350 and the M4 x 30 screws wont fit for the converters. They are a Little Bit too short to hold the y converters in Place. The screws get no grip. Can u please reach out to me with Further advice?
Thanks and regards
Mounting these two converters was the only part of the assembly that gave me ANY resistance. Everything else went perfectly smooth.
The outside bracket was just a hair narrower than the holes in the base plate. One side went in real easy, but then on the other side the hole in the base plate was slightly under the bracket just enough that the screw wouldn’t get in the hole to start threading.
I ended up getting it in by leaving the first side just barely started with converter pulled up to the head of the screw so there was a gap between it and the base plate. Then I was able to force the other screw into the hole. Now that both sides are under pressure, it took way more force than I’m comfortable with to tighten the screws down.
Was the same way with both converters.
thats better than mine which were stretched out so much i had to moosh em in for the screw to be able to grab
