Continue print after empty spool with different color
Hello there,
I understand that the U1 continues a print after a run out spool with a loaded spool only with the same material and color. For some purely functional prints the color does not really matter so it would be great if we could override the same color requirement. Would help tremendously with using up all those spools with just a small length of filament left…
Any chance?
Manually set to the same color
I think this is a perfectly reasonable use case. I’ll pass it on to our software team.
