No skin tone color option
Just printed a Slowpoke power ranger of which the mouth is supposed to be skin tone but instead is white. All my settings are correct; I know there’s an AI system that selects the closest color to what it has a necessity for. However, when selecting colors on the filament selector on the hardware there is not a skin tone color selector. Perhaps maybe i have something not quite right… an assist would help :slight_smile:
Just select some not used color and assign the mapping manually on print start.
You have max. four spools of filament attached to your printer of which you can choose. You can only print anyone of those colors. Or am I getting you wrong ? If e.g. you have a black, a red, a green and a white spool attached, those are the colors you can print.
If you’re using third-party filament, set the color and type on the machine when loading so the slicer can sync that info directly.
