hello there,
i’ve been wondering if there is a way to connect directly to an a350t 3d printer using orca rather than passing through luban which seems to cause a lot of issues ?
thanks a lot for your replies ![]()
hello there,
I thought Snorca already had that feature.
Not sure if the actual firmware is served over air.
You have to use the latest firmware, have a look here (instructions about sending from orca are also there):
thanks a ton, indeed after manual upgrade i was able to connect directly ![]()
