ORCA and SM2...how to get them to talk to each other?
I’ve been trying to understand (unsuccessfully obviously) how to get the new ORCA to see/talk to my SM2 A250 machine…
I’ve tried to follow the ‘instructions’ I find in the forum, but I don’t see the same screens as in the posts?
The only way I’ve been able to try ORCA is to generate a gcode file, then go back to Luban and read it and have Luban send it to my SM2 - there has to be a better/smoother way to do this, doesn’t ther???
Snapmaker Orca Release Notes | Snapmaker Wiki
You can use the official branch! Matching for 2.0 machines will be scheduled for a later update.
At present the company’s software resources aren’t enough to maintain an additional branch; we have to iterate on the company’s own version first, making sure it works well and is fully compatible with all company machines.
For the A250 you need to run Luban (or sm2uploader) with it connected to your printer in the background. This gives you a local Octo/Klipper proxy server (using IP and port 127.0.0.1:5000 by default) that can forward files over to the printer.
Then in Snapmaker Orca (or OrcaSlicer) you configure the printer to connect to that Octo/Klipper proxy (using a button with a WiFi-like symbol) using that IP and port.
Here are some docs on how to set this up:
Once those are running and configured you can print directly to the A250.
It’s not perfect but this works well for me. Hope that helps!
