Cannot connect using Orca
I try to use the brand new Snapmaker Orca slicer, but fail.
I did follow the wiki steps but it seems Luban blocks the connection.
Do you experience something similar ?
Have a look at the known bugs, the second one is for you:
Never tried orca yet so, hope this helps.
Ho, thanks for the forward.
You’re helpful, as usual :+1:
Follow-up: As port 5000 is used on mac for airplay reception, the solution is to disable the feature. But now Luban (from v4.15.0) lets you change the Octoprint port, and as long as you select a free port, everything works fine.
