CNC Toolpath
When I select “On the path” I get a perfectly valid carving tool path, but when I select “Outline” there are big gaps in the tool path. Any idea what may be wrong?
Luban is not very powerful for CNC carving.
It’s worth it to learn fusion or another cam software.
Here is a little tutorial about:
Need to see what your intended result is, and what tool you are using.
That’s the original drawing, I get a full tool path when I select “on the path”.
Is the source material SVG or a bitmap (JPG or PNG)? Best results are with SVG. If it isnt SVG, then download Inkscape (free) and convert it to an SVG.
I tried converting to SVG before, but Inkscape seems to have done the trick. Thanks!
