The screw to my CNC module is stripped and I can’t exchange the bits. Any ideas on how to remove it?
Its been a while, but IIRC, if you remove the sidepanel of the CNC Module, a bit above the “Tool Setscrew” is the other screw that holds the flanch onto the Motorshaft. Its the same size so maybe you can remove the whole Assembly there and drill out the stuck screw or try to get a replacement part of some sorts?
